435
Coded UI Tests: Problems with Menu Items
Dear Sir/Madam,
I am trying to generate some UI tests using the Visual Studio Ultimate 2012 (ver 11.0.61030.00 Uptdate 4) tools and having several problems to catch the actions over Infragistics components.
I have attached a very simple project with a UI, a test case and the log file generated when fails in order you can have a better look about what is the problem and how to reproduce it.
Test is very simple:
1) Launch the program
2) Clic on "PopupMenuTool1"
3) Clic on any button from the submenu.
Test fails trying to perform the steps 2 and 3 as you can see in the logfile.
Another control is blocking the control. Please make the blocked control visible and retry the action. Additional Details: TechnologyName: 'MSAA' ControlType: 'Menu'
Microsoft.VisualStudio.TestTools.UITest.Extension.FailedToPerformActionOnBlockedControlException
Thank you very much, I'm looking forward for some information about how to solve this problem.
InfUIExample.zip
