125
UltraGrid with UltraDropDown slow in painting
I have a tab control with three tabs. One of the tabs has an ultragrid on it. I set up the grid column to use UltraDropDown to select items. I want the column to show texts but store number internally. After the form is loaded, I try to switch between tabs. When I select the tab with grid on it, it takes a while for the contents of the grid to load(paint). When there are more rows on the grid, it takes even longer. When I set Visual Studio to show all exceptions, I got the exception "Input string not in correct format". If I setup the DisplayMember and ValueMember to be the same, the grid loads right away without delay. I assume there might be something wrong with my setup and it's slowing it down. I have attached sample code. Not sure if I set up everything correctly.
Jason
test.zip
