I have an Ultrawingrid that shows a relation between two tables. When I enlarge (or reduce) the width of a column at run time also the parent column above is resized: can I change this behaviour? I would like to resize indipendently child and parent columns.
Salo
it works perfectly, thank you very much! ;-)
Set this property:
ultraGrid1.DisplayLayout.Override.AllowColSizing = AllowColSizing.Free;
This allows the columns in each band to be sized independently.
