2060
UltraComboEditor - 14.2 - MouseWheel event not firing
I'm trying to stop the list in a UltraComboEditor from scrolling when the user uses the mouse wheel.
I've managed to do it on the UltraCombo by setting the following on the MouseWheel event of the control
Private Sub UltraCombo1_MouseWheel(sender As Object, e As MouseEventArgs) Handles UltraCombo1.MouseWheel
Dim mwe As HandledMouseEventArgs = DirectCast(e, HandledMouseEventArgs)
mwe.Handled = True
End Sub
However when I try to do the same on the UltraComboEditor the MouseWheel event doesn't seem to fire.
Private Sub UltraComboEditor1_MouseWheel(sender As Object, e As MouseEventArgs) Handles UltraComboEditor1.MouseWheel
mwe.Handled = True
End Sub
I've tried it on versions 13.2, 14.1 and 14.2 with the same result.
Is there an alternative approach for UltraComboEditors?
Kind regards,
Nathan
  • 29065
    Hello Nathan,
    I have opened a private case for you so that I can link it to an internal development issue. This way you will be notified automatically when the development issue is updated. The case number is CAS-146486-C1D2Y4. You will see it located here: https://ko.infragistics.com/my-account/support-activity
    Let me know if you have any questions regarding this matter.
  • 469350
    Verified Answer
    Hi Nathan,
    Both the UltraCombo and the UltraComboEditor show a TextBox control over themselves when in edit mode. This TextBox control gets the MouseWheel message.
    The UltraCombo is handling that MouseWheel message and passing it on to you. The UltraComboEditor is not. So this seems like a bug we need to look into.
    In the mean time, you can work around this by handling the MouseWheel event of the TextBox:
        Private Sub UltraComboEditor1_ControlAdded(sender As System.Object, e As System.Windows.Forms.ControlEventArgs) Handles UltraComboEditor1.ControlAdded
            AddHandler e.Control.MouseWheel, AddressOf Me.UltraComboEditor1_MouseWheel
        End Sub
        Private Sub UltraComboEditor1_ControlRemoved(sender As System.Object, e As System.Windows.Forms.ControlEventArgs) Handles UltraComboEditor1.ControlRemoved
            RemoveHandler e.Control.MouseWheel, AddressOf Me.UltraComboEditor1_MouseWheel
        End Sub
        Private Sub UltraComboEditor1_MouseWheel(sender As System.Object, e As System.Windows.Forms.HandledMouseEventArgs) Handles UltraComboEditor1.MouseWheel
            e.Handled = True
        End Sub
