790
Tab order and updates that "unhide" hidden columns.
I have a situation involving three columns in a grid.  Because I am not feeling creative lets call them 1, 2, and 3. :-)
At the beginning of the flow, a cell in column 1 is active, column 2 is hidden, and column 3 is visible and enabled.
If I make a change to column 1 that will cause column 2 to "unhide" and tab out, column 2 appears, but the active cell moves to column 3. It appears that at the time of the tab press, the destination column is already determined.  It makes sense...the grid has no way of knowing that column 2 is about to be available.
However, I would really like the active cell to land on column 2.
Can you suggest a good mechanism to make this happen?  I have something that works, but I don't think it is the most elegant solution...and I have to assume this is a pretty common issue.
Thank You!
Darin
