I'm using Infragistics Windows forms 2014.1 on a Surface Pro 3, Windows 8.1.
I'm using .net framework 4.0 in my Application.
When I move the mouse over the ribbon, the icons are jumping up and down causing flikkering.
Running the same code trom a Windows 7 installation, there is no problem with the ribbon.
Please Advice,
Peter
Hi Jiri,
Without any code, we haven't been able to reproduce this issue on our end. If there is anything that you can send over, it would help us in our investigation. Please let me know.
I have the same problem on a normal Windows 8.1 laptop. The application also works fine on Windows 7. Any solution yet?
My guess is that this is not a question of how we are using the ribbon but a problem related to display settings. It looks like the ribbon tabs are first drawn with a larger font and then again with the correct font. Because the ribbon tab takes more vertical space when drawn with the larger font it 'jumps down' and then 'jumps up' when drawn with the correct font causing the flickering.
Hi Peter,
We have a Surface Pro here on which we can test. Can you provide a reproduction sample so that I can look into this?
