2325
stopping validating event when pressing cancel button doesnt work
I have a winform that has an ultratextbox and 2 ultrabuttons.  The cancel button has its causesvalidation property set to false in the form_load event.  The textbox has code in the validating event to check/validate the contents of the text box.  When the form loads I press the cancel button, the validating event fires.  It was my understanding that by setting the CausesValidation property to false this would prevent any controls validating even from firing.  How can I keep the textbox from validating when I press the cancel button?
  • 12480
    Verified Answer
    Setting the CausesValidation property to false should have the effect you are expecting. I have created a small sample in which I attempted to reproduce this. It is attached here. Please take a look at the sample and see if you are able to modify it to reproduce the issue.
    CausesValidation.zip
