395
Removing UltraCurrencyEditor padding characters
How do I remove the padding characters from the UltraCurrencyEditor so the '$' is displayed next to the value in edit mode? Currently when the user clicks the control the '$' is put on the left leaving a large space between it and the value.
  • 12480
    Suggested Answer
    Hi Alkali,
    UltraCurrencyEditor is designed to display a fixed amount of digits. By default, it leaves space for seven-digit values, with two decimal places. You can edit the MaskInput property in order to change this. For example, a mask like "$n,nnn.nn" would be appropriate for values in the thousands.
    Please refer to the MaskInput documentation for more information on which characters are allowed in a mask:
    http://help.infragistics.com/doc/WinForms/2014.2/CLR4.0/?page=Infragistics4.Win.UltraWinEditors.v14.2~Infragistics.Win.UltraWinEditors.UltraNumericEditorBase~MaskInput.html
    If you would like UltraCurrencyEditor to support a dynamically resizing mask, please consider submitting a product idea.
