I am attempting to update the contents of some cells hen the row has focus and when it does not. I thought i could accomplish this by setting the cell value in those events. When i set the value i can see in code that it shows as updated but the grid never reflects the change. If I then go back to that row and look at the value it has reverted to what it was before i tried changing it. This is a bould grid that I have addd 2 unbound columns to. The unbound columns are formattedText
Private Sub grdResults_BeforeRowDeactivate(sender As Object, e As System.ComponentModel.CancelEventArgs) Handles grdResults.BeforeRowDeactivate Dim activeRow As UltraGridRow = grdResults.ActiveRow Dim strDisplay As String Dim strNumberDisplay As String Dim strTypeDisplay As String
strDisplay = "<p><span style=""font-size: 12pt; line-height: 1.44; color: black;"">" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(CStr(activeRow.Cells("Name").Value), VbStrConv.ProperCase)) + "</span></p>"
strDisplay = strDisplay + " " + "<span style=""font-size: 10pt; line-height: 1.44; color: #666666;"">" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(activeRow.Cells("Address1").Value, VbStrConv.ProperCase)) + "</span>"
strDisplay = strDisplay.Replace(StrConv(_searchFileter, VbStrConv.ProperCase), "<b>" + StrConv(_searchFileter, VbStrConv.ProperCase) + "</b>")
strTypeDisplay = "" If activeRow.Cells("Status").Value = "A" Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(51), 16, 16, 3, 10) Else strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(53), 16, 16, 3, 10) End If
If activeRow.Cells("ResultType").Value = CentralSearchResultType.Customer Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(41), 16, 16, 3, 10) ElseIf activeRow.Cells("ResultType").Value = CentralSearchResultType.Vendor Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(45), 16, 16, 3, 10) Else strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(49), 16, 16, 3, 10) End If
strNumberDisplay = "<p align=""right""><span style=""font-size: 10pt; line-height: 1.44; color: #666666;"">#" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(activeRow.Cells("AccountNumber").Value, VbStrConv.ProperCase)) + "</span></p>" strNumberDisplay = strNumberDisplay.Replace(StrConv(_searchFileter, VbStrConv.ProperCase), "<b>" + StrConv(_searchFileter, VbStrConv.ProperCase) + "</b>") strNumberDisplay = strNumberDisplay + strTypeDisplay
activeRow.Cells("DisplayMatch").Value = "DEACTIVATE"
activeRow.Cells("DisplayMatchNumber").Value = "DEACTIVATE" End Sub
I even set the values of the cells to just be a text word to try to test this but the value never updates.
Private Sub grdResults_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles grdResults.InitializeLayout
grdResults.UseAppStyling = False grdResults.UseOsThemes = DefaultableBoolean.False grdResults.DisplayLayout.Override.ActiveRowAppearance.BackColor = Color.FromArgb(238, 238, 238) grdResults.DisplayLayout.Override.ActiveRowAppearance.ForeColor = Color.Black grdResults.DisplayLayout.Override.ActiveRowAppearance.BorderColor = Color.Black grdResults.DisplayLayout.Override.ActiveRowAppearance.BorderAlpha = Alpha.Transparent grdResults.DisplayLayout.Override.HeaderAppearance.BackColor = Color.White 'FromArgb(210, 226, 223) grdResults.DisplayLayout.Override.HeaderAppearance.BackGradientStyle = GradientStyle.None grdResults.DisplayLayout.Override.HeaderAppearance.BorderAlpha = Alpha.Opaque grdResults.DisplayLayout.Override.BorderStyleCell = UIElementBorderStyle.None grdResults.DisplayLayout.Override.RowAppearance.BorderColor = Color.FromArgb(204, 204, 204) grdResults.DisplayLayout.Appearance.BackColor = Color.White grdResults.DisplayLayout.Appearance.BorderAlpha = Alpha.Transparent grdResults.DisplayLayout.Override.RowAppearance.BackColor = Color.White grdResults.DisplayLayout.Override.DefaultRowHeight = 55 grdResults.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect grdResults.DisplayLayout.ViewStyleBand = ViewStyleBand.Vertical grdResults.DisplayLayout.Bands(0).ColHeadersVisible = False
grdResults.DisplayLayout.Override.CellAppearance.TextVAlign = VAlign.Middle grdResults.DisplayLayout.Override.CellAppearance.ImageVAlign = VAlign.Middle grdResults.DisplayLayout.Override.RowSizing = RowSizing.AutoFixed
grdResults.DisplayLayout.AutoFitStyle = AutoFitStyle.ExtendLastColumn
For Each ugc As UltraGridColumn In grdResults.DisplayLayout.Bands(0).Columns If ugc.Key <> "DisplayMatch" And ugc.Key <> "DisplayMatchNumber" Then 'AndAlso ugc.Key <> "Yprevbal" AndAlso ugc.Key <> "PastDueBalance" 'AndAlso ugc.Key <> "TaxPropertyMasterId" Then ugc.Hidden = True ElseIf ugc.Key = "DisplayMatch" Then ugc.Width = grdResults.Width - 180 'ElseIf ugc.Key = "DisplayMatchTypeIcon" Then ' ugc.Width = grdResults.Width - 40 End If ugc.CellActivation = Activation.NoEdit Next
End Sub
Private Sub grdResults_InitializeRow(sender As Object, e As InitializeRowEventArgs) Handles grdResults.InitializeRow Dim strDisplay As String Dim strNumberDisplay As String Dim strTypeDisplay As String
strDisplay = "<p><span style=""font-size: 12pt; line-height: 1.44; color: black;"">" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(CStr(e.Row.Cells("Name").Value), VbStrConv.ProperCase)) + "</span></p>"
strDisplay = strDisplay + " " + "<span style=""font-size: 10pt; line-height: 1.44; color: #666666;"">" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(e.Row.Cells("Address1").Value, VbStrConv.ProperCase)) + "</span>"
strTypeDisplay = "" If e.Row.Cells("Status").Value = "A" Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(52), 16, 16, 3, 10) Else strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(54), 16, 16, 3, 10) End If
If e.Row.Cells("ResultType").Value = CentralSearchResultType.Customer Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(40), 16, 16, 3, 10) ElseIf e.Row.Cells("ResultType").Value = CentralSearchResultType.Vendor Then strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(44), 16, 16, 3, 10) Else strTypeDisplay = strTypeDisplay + GetImageTag(CsiImageResources.CsiImageList.Images(48), 16, 16, 3, 10) End If
strNumberDisplay = "<p align=""right""><span style=""font-size: 10pt; line-height: 1.44; color: #666666;"">#" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(e.Row.Cells("AccountNumber").Value, VbStrConv.ProperCase)) + "</span></p>" strNumberDisplay = strNumberDisplay.Replace(StrConv(_searchFileter, VbStrConv.ProperCase), "<b>" + StrConv(_searchFileter, VbStrConv.ProperCase) + "</b>") strNumberDisplay = strNumberDisplay + strTypeDisplay
e.Row.Cells("DisplayMatch").Value = strDisplay
e.Row.Cells("DisplayMatchNumber").Value = strNumberDisplay End Sub
That did the trick. thanks so much to the both of you for your help.
It sounds like you need to check e.ReInitialize inside of InitializeRow. You only want to initialize the cell value when ReInitialize is false, so you only do it the first time.
Your program does work correctly but the problem is I also use the initializeRow event to initially put the data in the unbound columns I need. If I add this event to your program it overwrites anything the other 2 events put into the cell. I guess I need to understand how I get around this. Is there a different event I need to use to get the data into the unbound cells initially. This was the event suggested in a few other posts in this forum.
Hello Dave,
Do you have any additional quesitons regarding the UltraWinGrid?
Thank you for clarifying your requirements. I put together a sample application using our latest version of our controls, 2014 Volume 2, and I have had successful results.
The BeforeRowActivate and AfterRowDeactivate events are working as expected and update the cells value wen clicking rows. I used your code against a bound, unbound, and unbound formatted column with an embeddable UltraFormattedText editor and each one is updating accordingly.
Please review my sample and let me know if it achieves what you are looking for. If it does not and/or have any additional questions please let me know.
If you are not already using our latest and would like to upgrade you can start by referring to our forums for more details.
Thanks again and I look forward hearing from you.
