Is there any more documentation / blog posts, etc.. about the use case of the Data Chart vs. WinChart?
Is the DataChart the more modern version of WinChart?
Why would I use one over the other?
Please take a look at the documentation for each of our chart controls.
WinChart: http://help.infragistics.com/doc/WinForms/2014.2/CLR4.0/?page=WinChart.htmlDataChart: http://help.infragistics.com/doc/WinForms/2014.2/CLR4.0/?page=DataChart_DataChart.html
If you have used our XamChart, I definitely recommend DataChart because it will be familiar to you. If you have experience with neither chart, I still recommend using DataChart because it has performance advantages over WinChart, and because DataChart's feature set is expanding rapidly.
WinChart may be a better choice in certain use cases, however. How are you planning on presenting your data? Please let me know and I can give you a more personalized recommendation.
