Right now on the DayView mode, it shows the appointment box as follows:
If the time characters are xx:xxpm-x:xxpm it shows:
12:40pm-1:00pm Customer, Test
Description Here
Any way to get rid of it showing the start/end time? I just want the customer name to appear first.
Furthermore, if the time format takes less characters such as x:xxpm-x:xxpm it wraps and only shows the customer name.
For example, if the time is 2:00pm-2:40pm it displays nicely customer name only unless you hover over to get the tooltip.
Hello Jeff,
Thank you for contacting Infragistics Developer Support.
I am glad that you have resolved your issue. Let me know if you have any additional questions.
The answer here solved the problem. Thank you!
http://ko.infragistics.com/community/forums/p/15692/57410.aspx#57410
