i have two data tables dt1 and dt2,and the result should be present in dt3 and attach to ultragrid using c#
dt1id name1 data12 data2 3 data34 data4
dt2id name1 data52 data6
result should be dt3id name3 data34 data4
Please let me know if you need my further assistance on this matter.
Thank you for your feedback.
Regarding your first question please check the forum thread in the link bellow. There is a sample showing how to save and load data table to/from XML file http://ko.infragistics.com/community/forums/p/93370/461821.aspx#461821
Regarding your second question please find attached a sample solution implementing this approach.
Can you please provide me the sample code for saving and moreover i tried to change the color of row,it is not working
Here is the answers for your questions:
1. How should i save the changes made (drag and drop)in the ultragrid having grouping hierarchy – you can update your DataTable and then you can serialize it back to its original source.
2. i need only row 1,a and 5,e to have a different color – to change row appearance you need to set the appearance of the row not the appearance of the column. You may use code like this:
ultraGrid.Rows[yourRowIndex].Appearance.BackColor = Color.Red;
hi,im having data in the ultragrid as followsid name1 a2 b3 c4 d5 e6 f7 gi need only row 1,a and 5,e to have a different colori have tried this e.Layout.Bands[0].Columns[2].CellAppearance.BackColor = Color.LightPink; but it is giving entire column as pink. Thanks in advance
