905
UltraTextEditor
how do I know is any character in UltraTextEditor?
for example:
user typed نام خانوادگی
and I want to know text that user typed begin with "نام" or not
  • 8607
    Hello fatemeh,
    UltraTextEditor.Text property is a String type.  Because of this, you can use the .NET String.StartsWith method.
    For example:
    this.ultraTextEditor1.Text.StartsWith("e")
    Here is the MSDN link for that method.
    String.StartsWith
    If you need to determine if a character or string is in the text at all, you can use the Contains method.  You can also use IndexOf and compare the index if you need to determine if a character or string is located at a particular index.  However, if you just want to know if the text starts with a character, it's much easier to use StartsWith.
    Elizabeth Albert
    Localization Engineer
