http://help.infragistics.com/Help/Doc/WinForms/2012.1/CLR2.0/html/WinTilePanel_Adding_Multiple_Controls_to_a_Tile_in_WinTilePanel.html
Following the above example, we add a new tile
Dim utp1 As Infragistics.Win.Misc.UltraTilePanel '//THE ULTRA-TILEPANEL PANEL
Dim tile1 As New Infragistics.Win.Misc.UltraTile() '//THE ULTRA-TILE
Dim upTilesPanel As New UltraPanel '//THE ULTRA-PANEL
utp1.Tiles.Add(tile1) '//ADD TILE TO TILEPANEL
tile1.Control = upTilesPanel '//ADD PANEL TO TILE
then we add contols:
a textbox(s):
Dim txt1 As New TextBox
txt1.name = "TXT1NAME"
txt1.Width = upTilesPanel.ClientArea.Width - 23 txt1.Anchor = AnchorStyles.Left Or AnchorStyles.Right upTilesPanel.ClientArea.Controls.Add(txt1) '//ADD TEXTBOX TO PANEL
A datetimepicker..
Dim dat1 As New DateTimePicker
dat1.name = "DAT1NAME"
dat1.Width = upTilesPanel.ClientArea.Width - 23 dat1.Anchor = AnchorStyles.Left Or AnchorStyles.Right upTilesPanel.ClientArea.Controls.Add(dat1)
a button
Dim btn1 as new button
btn1.Width = upTilesPanel.ClientArea.Width - 23
btn1.Font = New Font("", 10, FontStyle.Bold) upTilesPanel.ClientArea.Controls.Add(btn1) AddHandler btn1.Click, AddressOf TileButtonClicked
..and so on
The problem, when the button is clicked, we want to get the txt in the textbox, and the value of the datetimepicker
For example sakes, lets just use MSGBOX()
Private Sub TileButtonClicked(sender As Object, e As EventArgs)
MSGBOX (upt1.tiles(0).controls(0).ClientArea.Controls("DAT1NAME").text ) '??ERR:
MSGBOX (upt1.tiles(0).controls(0).ClientArea.Controls("TXT1NAME").text ) '??ERR:
MSGBOX( ???? ) '//HOW TO PRINT CONTROL (0).TEXT & CONTROL(1).VALUE
End Sub
Hi Stan,
Thank you for your feedback.
I am glad that you have resolved your issue. Let me know if you have any additional questions.
Ive solved this by making the panel global.
The panel cannot be disposed or it will give errors if you reuse the panel
It can be called as so
Dim tempdtp As DateTimePicker = upTilesPanel.ClientArea.Controls("DAT1NAME")
'from.Controls.ClientArea.Controls()MSGBOX( tempdtp.Value.tostring ) ''GET SECOND DATETIME tempdtp = upTilesPanel.ClientArea.Controls("DAT2NAME") MSGBOX ( tempdtp.Value.tostring)
Dim temptxt As TextBox = upTilesPanel.ClientArea.Controls("TXT1NAME")
MSGBOX( temptxt.text )
Hello Stan,
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
Thank you for contacting Infragistics Developers Support.
The issue you are facing is a result of the object you are getting by this statement:
upt1.Tiles(0).Control
When you call this you are getting the UltraTilePanel’s (upt1) first UltraTile’s (tile1) control as Windows.Forms.Control. In your case the actual type of this control is UltraPanel and you need cast it to the actual type in order to reach its ClientArea property. You may use code like this:
Dim MyPanel As UltraPanel = DirectCast(Me.upt1.Tiles(0).Control, Infragistics.Win.Misc.UltraPanel)
Then you can get the controls you need like this:
MsgBox(MyPanel.ClientArea.Controls("DAT1NAME").Text)
MsgBox(MyPanel.ClientArea.Controls("TXT1NAME").Text)
Please find attached a small sample project implementing this approach.
Please let me know if you need any further assistance.
