How can i Change the Backcolor of the Ultrawingrid when using appstyling?
I have tried
GridKoepfe.DisplayLayout.Appearance.BackColor = Color.Red
nothing happend, but if i use
GridKoepfe.UseAppStyling = False
the Background of the grid is corretly Change but all other styles are gone.
How can i ovverride the Color for a specific grid without remove all other styles?
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
I’ve corrected your isl file so now setting of appearance over UltraGrid should take precedence over this from isl file.
<?xml version="1.0" encoding="utf-8"?><styleLibrary office2007ColorScheme="Black" office2007CustomBlendColor=""> <annotation> <lastModified>2008-04-28T17:51:39</lastModified> </annotation> <styleSets defaultStyleSet="Default"> <styleSet name="Default" viewStyle="Office2007"> <componentStyles> <componentStyle name="Inbox CheckBox"> <properties> <property name="BackColor" colorCategory="{Default}">Transparent</property> </properties> </componentStyle> <componentStyle name="Inbox Label"> <properties> <property name="BackColor" colorCategory="{Default}">Transparent</property> </properties> </componentStyle> <componentStyle name="Inbox MonthCalendar"> <properties> <property name="TitleBackColor" colorCategory="{Default}">224, 224, 224</property> <property name="TitleForeColor" colorCategory="{Default}">64, 64, 64</property> </properties> </componentStyle> <componentStyle name="Inbox RadioButton"> <properties> <property name="BackColor" colorCategory="{Default}">Transparent</property> </properties> </componentStyle> <componentStyle name="Inbox ListView"> <properties> <property name="BorderStyle" colorCategory="{Default}">FixedSingle</property> <property name="Font" colorCategory="{Default}">Segoe UI, 8.25pt</property> <property name="View" colorCategory="{Default}">Details</property> </properties> </componentStyle> <componentStyle name="Inbox MonthCalendar"> <properties> <property name="BackColor" colorCategory="{Default}">White</property> <property name="Font" colorCategory="{Default}">Segoe UI, 8.25pt</property> <property name="ForeColor" colorCategory="{Default}">64, 64, 64</property> <property name="TitleBackColor" colorCategory="{Default}">220, 222, 227</property> <property name="TitleForeColor" colorCategory="{Default}">64, 64, 64</property> </properties> </componentStyle> <componentStyle name="Inbox Panel"> <properties> <property name="BackColor" colorCategory="{Default}">Transparent</property> </properties> </componentStyle> <componentStyle name="Inbox UserControl"> <properties> <property name="BackColor" colorCategory="{Default}">Transparent</property> </properties> </componentStyle> <componentStyle name="UltraCalculator" useFlatMode="True" /> <componentStyle name="UltraDockManager" useFlatMode="True"> <properties> <property name="GroupPaneTabStyle" colorCategory="{Default}">Flat</property> </properties> </componentStyle> <componentStyle name="UltraDropDownButton" useFlatMode="True" /> <componentStyle name="UltraExplorerBar" useFlatMode="True" /> <componentStyle name="UltraGrid" useFlatMode="True" /> <componentStyle name="UltraListView" useFlatMode="True" /> <componentStyle name="UltraOptionSet"> <radioButtonGlyphInfo>Office2007RadioButtonGlyphInfo</radioButtonGlyphInfo> </componentStyle> <componentStyle name="UltraTabControl"> <properties> <property name="Style" colorCategory="{Default}">Office2007Ribbon</property> <property name="UseHotTracking" colorCategory="{Default}">True</property> </properties> </componentStyle> <componentStyle name="UltraTabStripControl" buttonStyle="FlatBorderless"> <properties> <property name="Style" colorCategory="{Default}">Office2007Ribbon</property> <property name="UseHotTracking" colorCategory="{Default}">True</property> </properties> </componentStyle> <componentStyle name="UltraToolbarsManager" useOsThemes="False" /> <componentStyle name="UltraTree" buttonStyle="FlatBorderless" useFlatMode="True" /> </componentStyles> <styles> <style role="Base"> <states> <state name="Normal" fontName="Segoe UI" themedElementAlpha="Transparent" /> <state name="HotTracked" fontName="Segoe UI" /> </states> </style> <style role="DesktopAlertButton"> <states> <state name="Normal" backColor="Transparent" borderColor="Transparent" backGradientStyle="None" backHatchStyle="None" /> <state name="HotTracked" backColor="Transparent" borderColor="Transparent" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="DesktopAlertCloseButton"> <states> <state name="Normal" foreColor="45, 45, 45" /> <state name="HotTracked"> <resources> <name>DesktopAlertDropDownButton_HotTracked</name> </resources> </state> </states> </style> <style role="DesktopAlertControlArea"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> </states> </style> <style role="DesktopAlertDropDownButton"> <states> <state name="Normal" backColor="Transparent" foreColor="45, 45, 45" backGradientStyle="None" backHatchStyle="None"> <resources> <name>spacer</name> </resources> </state> <state name="HotTracked"> <resources> <name>DesktopAlertDropDownButton_HotTracked</name> <name>spacer</name> </resources> </state> </states> </style> <style role="DesktopAlertGripArea"> <states> <state name="Normal"> <resources> <name>ScrollBarTrackHorizontalOffice2K7Black_Normal</name> </resources> </state> </states> </style> <style role="DesktopAlertLink"> <states> <state name="HotTracked" foreColor="Black" /> </states> </style> <style role="DesktopAlertPinButton"> <states> <state name="Normal" foreColor="45, 45, 45"> <resources> <name>spacer</name> </resources> </state> <state name="HotTracked"> <resources> <name>DesktopAlertDropDownButton_HotTracked</name> </resources> </state> </states> </style> <style role="DockSlidingGroupHeaderHorizontal"> <states> <state name="Normal" foreColor="White" /> </states> </style> <style role="DotNetMonthDropDown"> <states> <state name="Normal" backColor="White" fontName="Segoe UI" fontSize="8.25" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="DotNetMonthDropDownTitle"> <states> <state name="Normal" backColor="220, 222, 227" foreColor="64, 64, 64" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="ExpansionIndicator"> <states> <state name="Normal"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAALAEAAAKJUE5HDQoaCgAAAA1JSERSAAAACwAAAAsIBgAAAKmsdyYAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAAAlUlEQVQoU2P8//8/w8KNB/8zgMAPMAkGH9D4+fH2jAwLNhwAqoeCH///f4DhD///PwDhFx/+PwAyDDwS/iMU41F4Aa54BdBkAgov3ICZDFSMy2qQiSCFcMUTYIqB7vuA5k6Y4gMXoCaDFeNQBDIRpBBFMbKvka2GKURVDA0eXAoPnEByBigc8SncAFMMikFQgBPCIHUA7b139uJHN7cAAAAASUVORK5CYIILAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=</imageBackground> </state> <state name="Expanded"> <imageBackground>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</imageBackground> </state> </states> </style> <style role="ExplorerBarControlArea" borderStyle="None" /> <style role="ExplorerBarGroupHeader"> <states> <state name="Normal" borderColor="Transparent" /> </states> </style> <style role="GridAddNewBox"> <states> <state name="Normal"> <resources> <name>BackgroundAndBorder</name> </resources> </state> </states> </style> <style role="GridAddNewBoxButton"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> </states> </style> <style role="GridAddNewBoxPrompt"> <states> <state name="Normal" foreColor="60, 60, 60" /> </states> </style> <style role="GridCardCaption"> <states> <state name="Normal" backColor="235, 233, 237" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GridCell"> <states> <state name="Normal" borderColor="195, 195, 195" /> <state name="EditMode" backColor="Transparent" backGradientStyle="None" backHatchStyle="None"> <resources> <name>GridCellOffice2K7Black_EditMode</name> </resources> </state> </states> </style> <style role="GridCellProxy"> <states> <state name="Normal" backColor="232, 232, 232" borderColor="137, 137, 137" backGradientStyle="None" backHatchStyle="None" /> <state name="HotTracked" backColor="255, 255, 255" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GridColumnHeader"> <states> <state name="Normal"> <resources> <name>GridColumnHeaderOffice2K7_Normal</name> </resources> </state> <state name="HotTracked"> <resources> <name>GridColumnHeaderOffice2K7_HotTracked</name> </resources> </state> </states> </style> <style role="GridControlArea" borderStyle="Solid" buttonStyle="Flat"> <states> <state name="Normal" backColor="232, 232, 232" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GridGroupByBoxPrompt"> <states> <state name="Normal" backColor="Transparent" foreColor="96, 96, 96" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GridRow"> <states> <state name="Normal" borderColor="195, 195, 195" /> <state name="Selected"> <resources> <name>GridRowOffice2K7Black_Selected</name> </resources> </state> <state name="Active"> <resources> <name>GridRowOffice2K7Black_Active</name> </resources> </state> </states> </style> <style role="GridRowEditTemplatePanel"> <states> <state name="Normal" backColor="White" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GridRowSelector"> <states> <state name="Normal" backColor="232, 232, 232" borderColor="195, 195, 195" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="GroupPaneTabItemAreaHorizontalBottom"> <states> <state name="Normal" backColor="97, 97, 97" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="ListViewColumnHeader" borderStyle="None"> <states> <state name="Normal"> <resources> <name>GridColumnHeaderOffice2K7_Normal</name> </resources> </state> </states> </style> <style role="MenuSideStrip"> <states> <state name="Normal" foreColor="Black"> <resources> <name>GridColumnHeaderOffice2K7_Normal</name> </resources> </state> </states> </style> <style role="OptionSetEditorItem"> <states> <state name="Normal" themedElementAlpha="Opaque" /> </states> </style> <style role="ProgressBarFill"> <states> <state name="Normal"> <resources> <name>ProgressBarFill_Normal</name> </resources> </state> </states> </style> <style role="ScheduleDay"> <states> <state name="Selected" backColor="232, 234, 236" backGradientStyle="None" backHatchStyle="None" /> <state name="AlternateItem" backColor="199, 203, 209" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="ScheduleDayHeader"> <states> <state name="HotTracked"> <imageBackground>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</imageBackground> </state> </states> </style> <style role="TabControlCloseButton"> <states> <state name="Normal" backColor="Transparent" borderColor="Transparent" imageBackgroundStyle="Centered" foregroundAlpha="Transparent" backGradientStyle="None" backHatchStyle="None"> <imageBackground>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</imageBackground> </state> <state name="HotTracked" imageBackgroundStyle="Centered"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAAPgIAAAKJUE5HDQoaCgAAAA1JSERSAAAAEQAAABEIBgAAADttR/oAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAA7BAAAOwQG4kWvtAAABp0lEQVQ4T52T2UpCURiFd09STxMRhBCUNqENF5oFvUKzZINZNjqGHKmOqaiVNtgARRdeNEBQD7Paa9c5dKwuTsLnZv//+hZHxaZuz3iLECIkcUjsvgpSmBCypDYd3ED9+c029OjLkjHc11+QLZ7bhh594ZRvV3d1HBaqtqFHX5b4Ub26x36+Yht69FVJsXKNTO5U0drhNDFmf83pfZa4R+V3UYV2dGLS5uiFAeeNdyNLj74q0fQS0nrZQnvnABppzNBTJS63D8HwLiYXd37Q0eWBwW97evRVSSSaNgumlnYxsxLHbDgJh3PYhHfOuTcK6X2VeJHQsmoxvRLD3FoKgUjaUmCUcc49c8zTc7m9fBIv9nPHmAnFMb++h4UtzVIQSh5Z7twzxzw9VdLj8cmfuKYWwe2MRVjXSohkyuD5/aMxxzw9+qJ30IeL2wf1BMsxHeG9ghI3DyrY1s+wkz1XJ++cc88c8/Toi76hUfnfecJS9ACrqbwKbh1WEc1fIl68RqJ0o07eOeeeOebp0Rf9w/5aYDmCx9d329CjLwZG/M2SnAT/gF7zB0T45EE06FGKAAAAAElFTkSuQmCCCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA</imageBackground> </state> <state name="Pressed"> <imageBackground>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</imageBackground> </state> </states> </style> <style role="TabControlTabCloseButton"> <states> <state name="Normal" imageBackgroundStyle="Centered" foregroundAlpha="Transparent"> <imageBackground>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</imageBackground> </state> <state name="HotTracked" backColor="Transparent" borderColor="Transparent" imageBackgroundStyle="Stretched" foregroundAlpha="Transparent" backGradientStyle="None" backHatchStyle="None"> <imageBackground>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</imageBackground> </state> <state name="Pressed" backColor="Transparent" borderColor="Transparent" imageBackgroundStyle="Centered" backGradientStyle="None" backHatchStyle="None"> <imageBackground>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</imageBackground> </state> </states> </style> <style role="TabItemAreaHorizontalTop"> <states> <state name="Normal" backColor="97, 97, 97" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="TabItemAreaVertical"> <states> <state name="Normal" backColor="97, 97, 97" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="ToolbarItemFontList"> <states> <state name="Normal" foreColor="White" /> </states> </style> <style role="ToolbarItemLabel"> <states> <state name="Normal" foreColor="White" /> </states> </style> <style role="ToolbarItemStateButton"> <states> <state name="Normal" foreColor="White" /> </states> </style> <style role="TreeCell"> <states> <state name="Normal" borderColor="195, 195, 195" /> </states> </style> <style role="TreeColumnHeader"> <states> <state name="Normal"> <resources> <name>GridColumnHeaderOffice2K7_Normal</name> </resources> </state> </states> </style> <style role="TreeNodeExpansionIndicator"> <states> <state name="Normal"> <imageBackground>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</imageBackground> </state> </states> </style> <style role="UltraButton" buttonStyle="FlatBorderless"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> <state name="HotTracked"> <resources> <name>Button_HotTracked</name> </resources> </state> </states> </style> <style role="UltraButtonDefault"> <states> <state name="Normal" borderAlpha="Transparent" /> </states> </style> <style role="UltraCalculator"> <states> <state name="Normal" backColor="White" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="UltraCalculatorButton" buttonStyle="FlatBorderless"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> <state name="HotTracked"> <resources> <name>Button_HotTracked</name> </resources> </state> </states> </style> <style role="UltraCalculatorButtonBase" buttonStyle="FlatBorderless"> <states> <state name="Normal" backColor="White" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="UltraCalculatorEditArea" borderStyle="Solid"> <states> <state name="Normal" backColor="White" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="UltraDropDownButtonMainButton"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> </states> </style> <style role="UltraDropDownButtonSplitButton"> <states> <state name="Normal"> <resources> <name>Button</name> </resources> </state> </states> </style> <style role="UltraOptionSet"> <states> <state name="Normal" themedElementAlpha="Opaque" /> </states> </style> <style role="UltraProgressBar" borderStyle="Rounded1"> <states> <state name="Normal" borderColor="Office2007.OutlookNavPaneBorder" /> </states> </style> <style role="UnpinnedTabAreaTop"> <states> <state name="Normal" backColor="97, 97, 97" backGradientStyle="None" backHatchStyle="None" /> </states> </style> <style role="ValueListItem"> <states> <state name="Selected" backColor="Office2007.AddRemoveHighlight" backGradientStyle="None" backHatchStyle="None" /> </states> </style> </styles> <sharedObjects> <sharedObject name="ScrollBar"> <properties> <property name="MinimumThumbHeight" colorCategory="{Default}">30</property> <property name="MinimumThumbWidth" colorCategory="{Default}">30</property> </properties> </sharedObject> </sharedObjects> </styleSet> <styleSet name="SpellCheckDialog"> <styles> <style role="UltraLabel"> <states> <state name="Normal" foreColor="Black" /> </states> </style> </styles> </styleSet> <styleSet name="SpellCheckDialog_DropShadow"> <styles> <style role="UltraLabel"> <states> <state name="Normal" foreColor="180, 180, 180" /> </states> </style> </styles> </styleSet> </styleSets> <resources> <resource name="BackgroundAndBorder" backColor="232, 232, 232" borderColor="137, 137, 137" backGradientStyle="None" backHatchStyle="None" /> <resource name="Button" foreColor="75, 75, 75" borderColor="Transparent" fontName="Segoe UI" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="2, 2, 2, 2"> <imageBackground>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</imageBackground> </resource> <resource name="Button_HotTracked" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="2, 2, 2, 2"> <imageBackground>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</imageBackground> </resource> <resource name="DesktopAlertDropDownButton_HotTracked" backColor="255, 231, 162" foreColor="Black" borderColor="255, 189, 105" backGradientStyle="None" backHatchStyle="None" /> <resource name="gradient_bg" backColor="White" borderColor="Transparent" backColor2="Gray" backGradientStyle="Vertical" borderColor2="Transparent" /> <resource name="GridCellOffice2K7Black_EditMode" backColor="Transparent" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="2, 2, 2, 2"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAATQEAAAKJUE5HDQoaCgAAAA1JSERSAAAAGQAAAB8IBgAAABKwZn4AAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAAAtklEQVRIS+2WsQoDIRBEPTvxo0J+/I58iaidrYiVbhwJR8osaKpdsJFlxn1uMYdzTllrr1rro/d+qEWltSZjzKuU8lQppSuEQMOEhgmtKuhBF/rKe99xsaNyzgR9NXBRa22Hx9SF/jTZWWLCoiu4BBeLAKtZtktwsQiwmmW7BBeLAKv5v9u1Mjl+j3nnLiS8kVdZCH5tvhPkyKpnjJFwsWoiTICHf7LwiQQ5QzcmwietOtCDLvTfKKCXZicmfD4AAAAASUVORK5CYIILAAAAAAAAAAAAAAAAAAAAAAA=</imageBackground> </resource> <resource name="GridColumnHeaderOffice2K7_HotTracked" backColor="Transparent" borderColor="242, 149, 54" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="2, 2, 2, 2"> <imageBackground>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</imageBackground> </resource> <resource name="GridColumnHeaderOffice2K7_Normal" backColor="246, 250, 251" foreColor="75, 75, 75" borderColor="195, 195, 195" imageBackgroundStyle="Stretched" fontBold="True" backColor2="210, 210, 210" backGradientStyle="Vertical" imageBackgroundStretchMargins="2, 2, 2, 2" /> <resource name="GridRowOffice2K7Black_Active" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="2, 2, 2, 2"> <imageBackground>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</imageBackground> </resource> <resource name="GridRowOffice2K7Black_Selected" foreColor="Black" imageBackgroundStyle="Stretched"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAACwEAAAKJUE5HDQoaCgAAAA1JSERSAAAACwAAABQIBgAAAFssx2gAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAAAdElEQVQ4T5XQOwrCYAAE4fX+9xHBwsLGxkKwESwshIAm8UUiPv6MOcK48HVT7YTSEzu+LVb41FgZ3iesDK8KK+V5xErpD+MhTkq3xwr1FOvPuJmBFJr5GDuhXWCFyxIrXFdY4bbGCvcNVnhssUK3wwrljPUDYL0XRV2kXHAAAAAASUVORK5CYIILAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=</imageBackground> </resource> <resource name="ProgressBarFill_Normal" backColor="Transparent" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="0, 1, 0, 1"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowDownOffice2k7Black_HotTracked" imageBackgroundStyle="Centered"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowDownOffice2k7Black_Normal" backColor="Transparent" foreColor="Transparent" imageBackgroundStyle="Centered" backGradientStyle="None" backHatchStyle="None"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowDownOffice2k7Black_Pressed"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowLeftOffice2k7Black_HotTracked"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowLeftOffice2k7Black_Normal" foreColor="Transparent" imageBackgroundStyle="Centered"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAAEAEAAAKJUE5HDQoaCgAAAA1JSERSAAAAEQAAABEIBgAAADttR/oAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAAAeUlEQVQ4T62UsQ3AIAwEP/uwAoKOBSip2IIJqFiCIRiCpT5ylypE+li67nWS35KvWiuhjnOOKvDeUwUhBKogxsgTrbXXzFEyxqAkmXNSkqy1KEn23pQlVvQvEhNJ6zxP/qnYlBJP2InfMsg5UwWlFKqg904V2D9RuQHs0xAOF5KuSgAAAABJRU5ErkJgggsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=</imageBackground> </resource> <resource name="ScrollBarArrowLeftOffice2k7Black_Pressed"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowRightOffice2k7Black_HotTracked" imageBackgroundStyle="Centered"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowRightOffice2k7Black_Normal" foreColor="Transparent" imageBackgroundStyle="Centered"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowRightOffice2k7Black_Pressed"> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAAXwIAAAKJUE5HDQoaCgAAAA1JSERSAAAAEQAAABEIBgAAADttR/oAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAAByElEQVQ4T6XUv0sbcRjH8es/oR0UOihu4i6lc4eKuLk4HGq0WFxa20wFF6WSrW6i8XRQKthojJW2NIRK6KHRVGOjPc2pCeaXwdOaH6by8fs84cRIwNocvNY3z/fXPZBlGVK5X0X9E1Q+7cXD1nf3VtX0EjWNzyBVN/fB6d+HL55m/tQFCxp59vs0j9BZQfj8L4tlLplPT+BRyxtINMGynsT4rxSb0M7Yx4MMW4pk4Ynl2LqIkx0RJ6ncJU/PEY92hLGNGFO2DaaqKqZCaTjDWbijBXdGRv1HIPatY0YRl8uFGT2NRTENUZMXLHCSZ8nsrUlG1iIg9kCCmRFFUeAQyyLfxZKIuW/x+0RsNltRxFxWUWTUuw15PsAsX0Ls5iQUsVqtGNfOmTOcYXvixK439l8i/f7T8iIUKIocikmEXXGHiidxbEAWOpc0Zi7nhTeJvhWDDQf/sA/ixAjdlZKR9oUgCEW6vup47o6gZznOrD6DvRch8lNcvJIReW4TpOPTDrN83kP3t0Nmxl6vGiDeeK4Qocc3NP8DtLk32VUNRFkNYXLtgE1vRdns7gmzqzrqWt9Cqn3cBHqN//OKG+RBtL0agET/k3JdAYhmKz1m5ql9AAAAAElFTkSuQmCCCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA</imageBackground> </resource> <resource name="ScrollBarArrowUpOffice2k7Black_HotTracked" imageBackgroundStyle="Centered"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowUpOffice2k7Black_Normal" foreColor="Transparent" imageBackgroundStyle="Centered"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarArrowUpOffice2k7Black_Pressed"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarThumbHorizontalOffice2k7Black_HotTracked"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarThumbHorizontalOffice2k7Black_Normal" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="2, 2, 2, 2"> <image>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</image> <imageBackground>AAEAAAD/////AQAAAAAAAAAMAgAAAFFTeXN0ZW0uRHJhd2luZywgVmVyc2lvbj0yLjAuMC4wLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWIwM2Y1ZjdmMTFkNTBhM2EFAQAAABVTeXN0ZW0uRHJhd2luZy5CaXRtYXABAAAABERhdGEHAgIAAAAJAwAAAA8DAAAABgIAAAKJUE5HDQoaCgAAAA1JSERSAAAAHQAAABEIBgAAACFRp3QAAAABc1JHQgCuzhzpAAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAACXBIWXMAAAsQAAALEAGtI711AAABb0lEQVRIS72VS2vCQBSF0z+kiCIquHLlD5ZubOvbKtGokTxtpFYqxmd8JOrmdO5II113dOBbf/ece2GeAEgPf5FIBNFo9GGQT0qlUjAMA6fTCefz+W5cLhdYloVMJnOV7vd77HZ7HI9Hhv9vfN/HXwIEwTUU+aR0Oo3NZov1eg3P8/gAojkcrmGoTfJx6Wq1hususGJiGkA0v2EobShdLleYz10sFks+gGgohOftWMXBTUqy2WzGxa67FA6F2G49vucwqeOMMRxqMEwblv0hnPH4E9PpN19bKB2NHPR6KhPr0DRTOLbtYDL5Yse6uUktewS5o3DxQNWEoxsWKC3VHCY1TQutlgxZVtDtDoRDDVKbdLChVNdNVGtNNJptvDO5aFrtDlTWIB0ql2azWbZDHa9vFZRKVZTLdeFUqg3U6i221ynIJ+VyORQKz1CUwd3o91WetFh8QT6fh0Q/TCwWQyKRuDvxeBzJZBIS/aeP5gevKtgv6D/mCgAAAABJRU5ErkJgggsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=</imageBackground> </resource> <resource name="ScrollBarThumbHorizontalOffice2k7Black_Pressed"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarThumbVerticalOffice2k7Black_HotTracked"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarThumbVerticalOffice2k7Black_Normal" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="2, 2, 2, 2"> <image>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</image> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarThumbVerticalOffice2k7Black_Pressed"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarTrackHorizontalOffice2K7Black_Normal" imageBackgroundStyle="Stretched"> <imageBackground>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</imageBackground> </resource> <resource name="ScrollBarTrackVerticalOffice2K7Black_Normal" borderColor="Transparent" imageBackgroundStyle="Stretched"> <imageBackground>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</imageBackground> </resource> <resource name="spacer" backColor="Transparent" borderColor="Transparent" backGradientStyle="None" backHatchStyle="None"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemHorizontalBottomOffice2k7Black_HotTracked" backColor="Transparent" borderColor="Transparent" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="5, 0, 5, 3"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemHorizontalBottomOffice2K7Black_Normal" backColor="97, 97, 97" foreColor="WhiteSmoke" borderColor="Transparent" backColorAlpha="Opaque" backGradientStyle="None" backHatchStyle="None" /> <resource name="TabControlTabItemHorizontalBottomOffice2k7Black_Selected" foreColor="Black" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="6, 0, 5, 3"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemHorizontalTopOffice2K7Black_HotTracked" backColor="Transparent" foreColor="White" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="4, 3, 4, 0"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemHorizontalTopOffice2K7Black_Normal" backColor="97, 97, 97" foreColor="White" backGradientStyle="None" backHatchStyle="None" /> <resource name="TabControlTabItemHorizontalTopOffice2K7Black_Selected" foreColor="Black" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="5, 4, 5, 0"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemVerticalLeftOffice2K7Black_HotTracked" backColor="Transparent" foreColor="WhiteSmoke" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="3, 2, 0, 2"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemVerticalLeftOffice2K7Black_Normal" backColor="97, 97, 97" foreColor="WhiteSmoke" borderColor="Transparent" backGradientStyle="None" backHatchStyle="None" /> <resource name="TabControlTabItemVerticalLeftOffice2K7Black_Selected" backColor="Transparent" foreColor="Black" borderColor="Transparent" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="3, 5, 0, 5"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemVerticalRightOffice2K7Black_HotTracked" backColor="Transparent" foreColor="WhiteSmoke" imageBackgroundStyle="Stretched" backGradientStyle="None" backHatchStyle="None" imageBackgroundStretchMargins="0, 5, 3, 5"> <imageBackground>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</imageBackground> </resource> <resource name="TabControlTabItemVerticalRightOffice2K7Black_Normal" backColor="97, 97, 97" foreColor="WhiteSmoke" borderColor="Transparent" backColorAlpha="Opaque" backGradientStyle="None" backHatchStyle="None" /> <resource name="TabControlTabItemVerticalRightOffice2K7Black_Selected" foreColor="Black" imageBackgroundStyle="Stretched" imageBackgroundStretchMargins="0, 5, 4, 5"> <imageBackground>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</imageBackground> </resource> </resources></styleLibrary>
I want to set the backcolor of a specific Grid in the Program
When you work with AppStylist you should know that all appearances which do not have a “Default” for a value will take precedence over the same setting managed via the application. In order to change this you could set ResolutionOrder via Appstylist on a control base level. Also we should highlight here that this is valid in case that you do not use Resources which covers the appearances. I think it will be easy if you could provide mi simple sample along with the used isl file and let me know which color should be changed. Then I will review your isl and will explain you what exactly you should set.
I am waiting for your feedback.
