I am using UltraColorPicker and there are 3 tabs 'Custom', 'System' and' Web'. Whenever drop-down opens by default 'Systems' Tab is in focus(or selected). I want 'Custom' tab to be on Focus(or selected) when while opening drop down. How can i achieve this?
Chitra
Hi Histro,
Thank you for your reply. It is working as expected.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Hello ,
UltraColorPicker activate this tab in which it find the current selected color. By default system color “Control” is selected and that is why “System” tab is activate. If you set RGB custom color for a value (which is not named color or system color), then “Custom” tab will be activated.
