Our customer uses a custom dictionary. In this dictionary he added lower case words like
At run-time we use this dictionary and care about case sensitivity. User enters a word in a text editor at run-time. For instance 'tHisa'. The spell checking doesn't show any error.
If user makes the same error with works from the English default dictionary, everything is fine. The word is underlined.
We use Infragistics4.Win.UltraWinSpellChecker.v13.1.
When user open spell check dialog and types in 'THisa' then the suggestion list shows 'Thisa' which is not included in the user dictionary.
sounds good. And when do you expect a fix?
best regards
Thank you for posting in our forums.
I was able to reproduce this behavior, so I have logged it in our internal issue tracking system with ID of 188128. In order to be notified as soon as this issue is fixed I have opened a private case for you - CAS-150564-F7P1G8. You can view your active cases from this link:
https://ko.infragistics.com/my-account/support-activity
