hello,
i got an UltraExplorerBar, Style ExplorerBar, v10.3, with UltraExplorerBarContainerControl Items.
1. I want a splitter between the Groups to resize them. Is this possible?
if not..
2. I want to auto-resize the groups when the other groups collapsed/expands, form resize etc. -I looked into HowTo but to call the resize function in the paint event is massively called.. -On top of that for me it ends in stackoverflow, even if i set the new high only if its different from the current height and if i ensure its not directly resurively called (hardly possible with events)
GreetingsJoerg
Hello Mike,
that looks nice! Good approach, ill add some more features.
And solve some other problems like http://ko.infragistics.com/community/forums/p/94883/468972.aspx#468972
Hi Joerg,
There's no easy way to add a splitter between groups. The splitter expects controls to be nested on either side of it, so each group would have to be its own control in that case.
I built a sample that resizes an expanded group to use up the rest of the vertical space on the form. I did not account for a situation in which the groups take up more space than is available, but logic can be added to revert to default behavior in this case. Please take a look at the sample and let me know whether it helps you achieve your requirement.
