How Can i add a image in application menu..
Hai All,
How are you?
I need to add a image in UltraDayView.. Kindly Please Help Me..
Oh!!!!!!!!! Thank You so much Sir.. It's Working......
Please open the link which I’ve provided and read the tutorial there.
If you use only the designer then the property is under UltraToolbarsManager1 -> Ribbon -> ApplicationMenuButtonImage in “Properties” explorer.
Thanks for your reply sir.. How can i set the AppliacationMenuButtonImage property.
You should set AppliacationMenuButtonImage property:
http://help.infragistics.com/Help/Doc/WinForms/2014.2/CLR4.0/html/Infragistics4.Win.UltraWinToolbars.v14.2~Infragistics.Win.UltraWinToolbars.Ribbon~ApplicationMenuButtonImage.html
Please let me know if you have any further questions or if I am missing something.
