45
get cell value from band of a hierarchical ultragrid
hi,
Plz can someone help me to know how to get cell value from a band of a hierarchical ultragrid ???
ex: i want to get the cell value at the "Customer" Column, 6Th Row in a band named "Band_3".
And Plz how to get the rowcount of a Band ?
Appreciated.
  • 12480
    Suggested Answer
    A band in a grid represents a set of columns. It's more like the schema then the actual data. For this reason, knowing the band isn't enough to access a specific row that uses that band. You would need to know the parent row. For example, if your data looked like this:
    Root 0
       Child 00
       Child 01
    Root 1
       Child 10
       Child 11
    You could access Child 10 with the following code:
    UltraGridRow row = ultraGrid1.Rows[1].ChildBands[0].Rows[0]
    If you wanted to access the value of the cell in the "Customer" column, you could then use this code:
    row.Cells["Column 0"].Value
    Value returns an object, so you might cast it to a string to display it on another control.
    Please let me know if this explanation helps you meet your requirement.
