920
ICustomSummaryCalculator select in SummarySelectionDialog
I have a Grid where I need to implement a ICustomSummaryCalculator for special calculation of a sum.
Now I want to appear the SummarySelection in the ColumnHeader (the sigma-sign) to let the user select if he wants to see the summary or not.
Now I have the problem, that the SummarySelection-Dialog, which appears when I click on the Sigma-sign, does not contain my summary. It only contains sum, count, average, ...
How can I achieve to get my calculation method to appear in this dialog?
Much better would be to be able to override the method, when the user clicks on "sum", so I am able to define what "sum" means. Is that possible, too?
Kind regards,
Wolfgang
  • 23930
    Hello Wolfgang,
    I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
  • 23930
    Hi Wolfgang,
    Thank you for posting in our forums.
    The UltraGrid allow you to create a custom SummaryDialog based on your needs. To do that, handle the BeforeSummaryDialog event and cancel it. Then you can show your custom summary dialog, which displays the necessary summary options.
    I have attached a sample which demonstrates this suggestion.
    Please let me know if you have any additional questions.
    WG_CustomSummaryDialog.zip
