How do I change the size of the drop down button? I have it set up for a touch screen activation but the size of the drop down button is fairly small since I am using font size 36 for everything else. The height of the button is fine but I would like to make it wider, for the people with fatter fingers.
Bernie
That worked for me. Sorry I forgot to verify the answer.
Hello Bernie,
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
You can increase the width of the button of UltraDropDown by implementing IUIElementCreationFilter interface. Please check this forum thread where same thing was discussed http://ko.infragistics.com/community/forums/t/34485.aspx
Thank you for using Infragistics Controls.
