At runtime, I get an error when the user drags a control from the WinExplorerBar and drops it outside the WinExplorerBar.
I know how to lock the items inside but can't find a way to prevent them to drop the control outside the WinExplorerBar.
TIA
After installed infragistics hotfix, you have to run Project Upgrade Utility to Upgrade your project and rebuild your solution.Also, you should set Specific Version to False
I have upgrade my solution and this error was corrected. Goodluck to you.
I installed the fix and didn't correct the problem.
The error is the same.
Please download and install hot fix 7.3.20073.1043 to correct this problem.
