The current version of MS DateTimePicker has a property "Checked" and an option "ShowCheckbox" which don't appear to be supported by the newest Infragistics NetAdvantage for Win DateTimeEditor. Is there something I'm missing or is there a workaround or will that support be coming soon?
Use the AfterEditorButtonCheckStateChanged event. There is also a BeforeEditorButtonCheckStateChanged event.
Hi,,
Me also face the Same problem. But i add checkbox in ultradatetime editor ... but i try to check and uncheck event is not working.. how to handle check and uncheck value
You are not missing anything. The UltraDateTimeEditor doesn't support this property. But it has something better... or at least a lot more flexible. :)
You can use the ButtonsRight and/or ButtonsLeft collection of the control to add buttons to UltraDateTimeEditor. Soif you want to add a checxbox, you could add a StateButton and set it to checkbox style. Then you would have the EditorButtonClick event of the control to set the value.
