Hi...I made this window program with Infragistics grid and UltraComboEditor like Infragistics-grid.png.But I have this problem.
Grid's column 2 (column Type) has UltraComboEdit in the cell. It has 2 items (Text, Image ).I want to do like that.If I select Text, the column 3 (column FileName/Value) shows a textBox and column 4 (column Blink)'s checkbox is checked.If I select Image, the column 3 (column FileName/Value) shows a textBox(ReadOnly) and a button ( for openfileDialog) and column 4 (column Blink)'s checkbox is unchecked.I want to know how to register the event handler and the Event function..My codes are as following
private readonly UltraComboEditor _ultraComboEditor1;
ColumnsCollection columns = ultraGrid1.DisplayLayout.Bands[0].Columns; // Initializing columns associating with embedded editors columns[2].EditorComponent = _ultraComboEditor1;
// Populating 5 rows of data for(int i=0;i<4;i++) _ultraComboEditor1.Items.Add(0, StateTypeName[i]);
Sorry my response is late...
Thank you for your help...
Hello Edward,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Hi Edward,
Thank you for the reply.
I have modified my sample in order to demonstrate how to add value list, when the value in the “Type” column is “Animation”. I have added a new case in the switch statement for in the CellChange event for the Animation value. If the value in the “Type” column is “Animation”, it will now assign a ValueList to the "FileName/Value" column with the desired options. If another option is selected in the “Type” column the ValueList is set to null.
Please let me know if you have any additional questions.
But I am a beginer in the Window programming..So, I can't do that...
Dimitar helped me ago.
Column "FileName/Value" is changed according to the column "Type"'s dropdownlist..
If column "Type" is selected "Text", the column "FileName/Value" shows textBox.And if column "Type" is selected "Image", it shows readOnly textBox with one button.And if column "Type" is selected "Animation", it shows comboBox dropdownlist that has the value "Image1", "Image2", "Image3" and "Image4".
The first two things are solved by Dimitar's help.It is very complex thing to me.Please give me a sample example.I can't find the similar example in your website..
Creating a dropdown list in a grid cell whose list values are dependent on another cell - Windows Forms - Infragistics Community
