Just an FYI: (Infragistics v14.2.20142.2092) Deleting a Tab (via the Tab control's designer) stripped the ToolbarManager In Place Designer from the UltraTabControl's Shared Controls tab page, so it would no longer show for any of the tabs. As far as I can tell, it also stripped the UltraPanel containing it as well. It did not actually delete the ToolbarManager, or alter it's DockWithinContainer property, however. In order to deal with this, you must locate the ToolbarManager control in the non-graphical tools area under the form (or select it by name in the Control selection box above the properties window) and manually set the DockWithinContainer property to a new container. You may then set it back to the Shared Controls tab page, where you will be prompted to create a new container. Do so, and you will again be blessed with the In Place Designer available from all of your tabs.
It would be great if y'all could take a look into this. It took me a while to figure out what what had happened and then, once the heart attack had passed, how to get the In Place designer to reappear. Sure, I use TFS, but who wants to store changes, back out of a day's worth of work, download and merge the changes, and then fear to delete a tab?
Thank you for the reply.
It seems that the difference was that I was using the "SmartTag" to remove the tab (as you can see in the video “tab4” is the active tab and it is the one that is removed) and the issue is reproducible if you use the “Custom Property Pages…” dialog. I was able to reproduce it using this dialog and I have logged it for further investigation in our internal issue tracking system with ID of 192116. I have also opened a private ticket - CAS-153340-M6Z6Y5 - for you so that you will be notified when the issue is fixed.
You can view your active cases if you follow this link:
https://ko.infragistics.com/my-account/support-activity
Are you able to reproduce the issue if the tab you are deleting is the active tab at the time of deletion? The mention of Just My Code was more a matter of disclosure than providing a possible reason for the issue.
I am using the 'Remove Tab' option from the Tabs editor dialog. Your attached video shows you deleting a tab with a different tab as the active tab; please try it while deleting the Actively visible tab.
Thank you for your reply.
I have tested this in Visual Studio 2013 and Just My Code disabled and the result is still the same – if I don’t delete the UltraToolbarsManager everything works fine. How are you removing the tabs? Do you use the “Remove Tab” option? Am I doing something differently than you in the attached video from my previous response?
I am looking forward to hearing from you.
I was able to reproduce the undesired behavior on my machine (Win7 x64; VS2013) with the example you sent as well as with my own project WITHOUT needing to first delete/undo the deletion of the ToolbarManager. The key seems to be having the Tab you are deleting be the active (visible) tab when you delete it. If a different tab is the active tab when you delete it, the problem does not occur, even if I have previously deleted and then undone the deletion of the ToolbarManager. For me, the only problem with undoing the deletion of the ToolbarManager is that the DockInContainer setting is set to Form1 instead of back to it's original value (the SharedControlsTabPage); it may be that other settings are also not restored but I wouldn't know without additional tinker time. So, there is also at least 1 minor issue with undoing the deletion of the ToolBarManager.
It may or may not be worth noting that I have 'Just My Code' disabled on my machine and it does a lot of symbol loading when the project loads and before I can make any changes. Probably no impact on the Infragistics design time UI, but I wouldn't know :).
Thank you for posting in our forums.
Maybe I am missing some steps, but I was only able to reproduce the described behavior, if I first deleted the UltraToolbarsManager then I undo the action. After that removing the tab leads to the described scenario. Otherwise removing the tab from the designer leaved the other tabs with the toolbars manager and the In Place Designer was working properly. Was that the case for you, too? I am attaching a video which demonstrates how this works on my machine along with the test sample which I used. Let me know if I am missing something.
If the behavior is only reproducible if you delete the UltraToolbarsManager first and then undoing the action my assumption would be that the undo action doesn’t do something properly.
