Hi Preeth,
I don't believe that a teamviewer session will be valuable in this case, since I will need to familiarize myself with the application before I can begin to debug. If there's anything that you can send over, I will look at it and do my best to find the issue.
HI
I am not able to map the datasource to the solution provided. Shall we have a teamviewer session at your convenience, so that i will be able to demonstrate how it works. Also note i am using windowsxp as to support the development - no skype available for IM. Kindly advise.
I wouldn't expect the exporter to behave in this way. Are you able to send a code sample that I can use to reproduce this issue? If you can send over some code, I should be able to determine why the cells are offset like that.
Hi Mike,
I was able to use it after merging the required dll with the version(8.2) I have.
But after spending some time with my application i was able to find out the reason for this. I even altered the e.CurrentColumnIndex value thinking it should help me and it has only when i keep the headers visible for the child bands. But the requirement is hiding the headers for the childbands and using the headers of the band 0 for all of them. This has caused the excel output to show as reported. This "ultraGridExcelExporter_HeaderRowExporting" method is triggered only once as there is only one header row i.e., for band 0.
Now, could you guide me how to make this work keeping the headers of the child bands hidden.
ThanksPreeth
I've saved the solution in VS 2008. Please let me know if it works for you.
