700
ComboEditor AddArray
In the MS standard windows controls the AddArray method will take any array as a parameter and you can then set Display and Data bindings.  The AddArray method for the UltraComboEditor only takes an array of ListItems.
 Is there a mechanism built in to pass an array of objects (for example a person object) and set what fields to bind to (say PersonId and PersonName) for data and display values without looping through the array and manually adding the items?
  • 469350
    Verified Answer
    You can bind the UltraCombo or UtraComboEditor using the DataSource/DataMember properties. You would use the ValueMember and DisplayMember to determine which fields are saved and displayed respectively.
