785
Setting multi-line header column fixed
Recently I was using winGrid and got a problem. When my grid's header has only one line, say I want to fix the first column then I could simply use the property XXXColumn.Header.Fixed to fix the column.
But when my grid's header has two line, is there any properties that I could also use to set the first column as fixed?
Thanks for your concern.
