I was working with ultragrid and wanted to add spaces between specific columns in the grid. For this I am using a drawfilter to hide specific groups in a grid. Everything worked good without theme. But as we applied the theme. The vertical line from the grid column header and the grid cell becomes jagged. I am attaching the sample with this. The theme is in the bin folder of application.
Regards
Sumeet Kumar
when theme is applied on grid column header and grid cell then jagged line are shown in between grid column header and grid cell
I am just checking about the progress of this issue. Let me know If you need my further assistance on this matter?
Hello ,
Thank you for the provided sample. It seems that the behavior which you are facing was a bug which is already fixed in the latest service release of Infragistics 14.2, I’ve verified that this appears in Infragistics 12.2 and that it is no longer an issue in the latest service release of 14.2. So please upgrade your project.
