410
Changing the highligt color on 3D pie chart
 I am trying to change the highlight color on the pieces of a 3d pie chart.  I see where you can change the color to a certian color but what I am trying to do is change the color of the pie piece to a light color of the pie pieces color.  Similar to what Control.Light.Light would to a control.
 The other thing that has me a little stumped is I would like to do is only highlight the pie chart piece on a mouse click and not a hover.
Any help is great.
Mike
  • 28496
    Verified Answer
    i recommend just setting the chart's Tooltips.Display property to Never and doing the highlighting in code in a ChartDataClicked event handler.  here's one solution which does this using a CustomLinear ColorModel and replacing the appropriate color whenever a slice is clicked:
    using Infragistics.UltraChart.Shared.Events;
    using Infragistics.UltraChart.Shared.Styles;
    private Color[ _Colors = new Color[ { Color.Red, Color.Green, Color.Blue };
    private Color[ _LightColors = new Color[ { Color.Pink, Color.Lime, Color.SkyBlue };
    private void Form1_Load(object sender, EventArgs e)
        this.ultraChart1.ColorModel.ModelStyle = ColorModels.CustomLinear;
        this.ultraChart1.ColorModel.CustomPalette = this._Colors;
    private void ultraChart1_ChartDataClicked(object sender, ChartDataEventArgs e)
        Color[ newColors = new Color[this._Colors.Length];
        this._Colors.CopyTo(newColors, 0);
        newColors[e.DataRow] = this._LightColors[e.DataRow];
        this.ultraChart1.ColorModel.CustomPalette = newColors;
