785
How to implement delete key with UltraComboEditor in UltraGrid?
Recently I'm using UltraGrid in my application.And here is the request, in the first column of the grid I have to use comboEditor column, with the columnStyle to DropDownList.
I customized the UltraComboEditor component, and implement the OnKeyDown event which when I press the "del" button, the value selected will be deleted and the comboEditor will show empty value(not really delete the value, only set with this.SelectedIndex=-1).
Meanwhile, I customized the UltraGrid component, and also implement the OnKeyDown event which should deal with the "del" button when press the "del" button on keyboard it will delete the comboEditor value, which just the effect shown above with the customized comboEditor.
But when I got focued on the comboEditor in the grid, and press the "del" button, it won't delete the value that selected in the comboEditor, which is what I want to implement.
Could you please help me with that? Thanks for your concern.
And I'll attach the sample code that I implement before.
WindowsFormsApplication8.zip
