210
Excel Export on Grid is not working properly.
I am trying to export a Grid into Excel file on which Grouping is applied on Some column(s).
But when I check that excel file, it shifts the first row under Grouped rows to one cells behind and thus my all values messes up.
e.g. In attched exported file, I have applied grouping on Name. So in Line number 10, there is an grouped entry with name "John". It looks fine untill not expanded but as soon as you expand it then first row under this grouping shifts to left by one cell and then in line number 12, it shown value 50 (value of Age) in the filed for Name (Under john) and so on.
I am using below method:-
 ExcelExporter.Export(grid.Value, workBook, 9, 0);
If I provide here "1" for starting column then it shifts all the values including summary to one cell in right.
Please let me know what function can I use here to achieve the proper export functionality.
Kuldeep Agrawal.
ExportedImproperly.rar
  • 21795
    Hello Kuldeep,
    I am just checking about the progress of this issue. Let me know if Mike's suggestion worked for you or if you need our further assistance.
  • 469350
    Suggested Answer
    If the columns aren't lining up then then something in your code could be manipulating the CurrentColumnIndex in one of the events of the Exporter.
    If that's not the problem, then my guess is you are using a version of the controls that had a bug in it. What version are you using? You might want to try getting the latest Service Release.
    How to get the latest service release - Windows Forms - Service Releases
