240
Regarding errors due to Older version of " Infragistics.Practices.CompositeUI.WinForms.dll " problem for 14.2 version of Infragistics for Upgradation from 11.1
Hi All,
        I am facing issue with Older version of  " Infragistics.Practices.CompositeUI.WinForms.dll " problem for 14.2 version of Infragistics for Upgradation from 11.1 ,
        when i am upgrading from 11.1 to 14.2 i have deleted all the older versions of Infragistics 11.1  and added only 14.2 version DLL'S,all works fine excepts this DLL  references ,  but along with this Older version of  " Infragistics.Practices.CompositeUI.WinForms.dll " , as i dont have newer version or Upgraded version of this DLL , kindly help me in this issue or provide me this DLL.
i am getting these 2 errors these are pointing to the  " Infragistics.Practices.CompositeUI.WinForms.dll (older version i have )" in the designer page i have checked .
Error 6 The type 'Infragistics.Win.UltraWinDock.UltraDockManager' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.Win.UltraWinDock.v11.1, Version=11.1.20111.2009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. C:\softwares\T3G\src\Infrastructure\Infrastructure.Library\UI\Views\T3gSearchEditViewBase.Designer.cs 336 82 Infrastructure.Library
Error 5 The type 'Infragistics.Win.UltraWinToolbars.UltraToolbarsManager' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.Win.UltraWinToolbars.v11.1, Version=11.1.20111.2009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. C:\softwares\T3G\src\Infrastructure\Infrastructure.Library\UI\Controls\StateMenuControl.designer.cs 127 91 Infrastructure.Library
