I would like to know how the column width is determined if I do not set it by default, I do not call the PerformAutoResize method on the column and the AutoFitStyle is set to None.
Is the width at this point calculated based on the header only or on the content only or both?
Thanks.
Annie
Recently I've asked the same question when contacting the Support. The answer was that it is some constant value (independent from header text or rows contents)
Hi Annie,
I'm not sure, but I think the column just uses some arbitrary defaults based on the data type. I don't think it takes the header into account at all and I'm sure it does not account for the data. But I could be wrong.
