1390
disabling check boxes
I'm using version 10.2 and C#. I have a grid that displays personnel records. I'm using a status column to show which records are available to be imported into our system and which ones are not (because they are missing some piece of information). The first column in the grid is a bool column so it displays checkboxes. The header of the column also has a checkbox so the user can select/unselect all. For the rows that can't be imported, I'm disabling the cell in the InitializeRow event based on specific criteria. The problem I have is when the user checks the header check box, all the checkboxes are getting checked and I only want the enabled check boxes (records that can be imported) to be checked. Is there a way to accomplish this?
