Hi
I have a bar chart (see attached PNG) and I use FillSceneGraph to add text at the top of each bar to show the impact of late timesheet completion on the data.
The issue is that the text font is too large, the text is not centered on the bar and text on adjacent bars run into each other. How do I specify a smaller font size when creating the text primitive and how do I center it on the bar?
I am using Infragistics 15.1 with latest service releases.
The code in FillSceneGraph is shown below.
Private Sub chartBottomLeft_FillSceneGraph(sender As Object, e As Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs) Handles chartBottomLeft.FillSceneGraph If Not _loadingData Then Dim sceneGraph As SceneGraph = e.SceneGraph Dim actual As Box Dim actualDataPoint As NumericDataPoint Dim textPrimitive As Infragistics.UltraChart.Core.Primitives.Text Dim primitivesToAdd As List(Of Infragistics.UltraChart.Core.Primitives.Text) = New List(Of Text)(5) Dim difference As Double Dim dtNoLate As DataTable = getChartDataWithoutLateTimesheetCompletion("Work Life Balance Report Data - Average Hours by Grade - No Late", lvwOfficeLocations, cboAverageHoursByGradeStartDate.Value, cboAverageHoursByGradeEndDate.Value) Dim rowIndex As Integer = 0 Dim colIndex As Integer = 1 For Each p As Primitive In sceneGraph actual = TryCast(p, Box) If actual IsNot Nothing Then actualDataPoint = TryCast(actual.DataPoint, NumericDataPoint) If actualDataPoint IsNot Nothing Then Dim index As Integer = sceneGraph.IndexOf(actual) If index <> -1 AndAlso index + 1 < sceneGraph.Count Then difference = (actualDataPoint.Value - dtNoLate.Rows(rowIndex)(colIndex)) / actualDataPoint.Value If Math.Abs(difference) > 0.0 Then Dim _location = New Point(actual.rect.Left + (actual.rect.Width / 2) - 10, actual.rect.Top - 8) textPrimitive = New Text(_location, difference.ToString("0.0%;-0.0%;0%")) primitivesToAdd.Add(textPrimitive) End If End If If colIndex = 3 Then rowIndex += 1 colIndex = 1 Else colIndex += 1 End If End If End If Next For Each _text As Text In primitivesToAdd sceneGraph.Add(_text) Next End If End Sub
Any help greatly appreciated.
Regards
James O'DOherty
Solution and Database Architect
WINSQL Ltd
Many thanks - exactly what I needed.
James
Hi James,
Thank you for posting in our forums.
Have you tried setting the labelStyle.Font property? Please let me know if the following code works for you:
myTextPrim.labelStyle.Font = new Font("Microsoft Sans Serif", 6.5f, FontStyle.Regular)
Please let me know if you have any additional questions.
