I am trying to display more owners in the UltraMonthViewSingle control. I have increased the MaximumOwnersInView property, but all that seems to do is scrunch the width until the calendar is unreadable. Is there any property that will let me add a second or third row of owners to this control?
My advice is to log this as new product ide here : http://ideas.infragistics.com, so we could track down this idea and implement it in some of our feature volume releases.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
[CASE: “Reference case [case number], FORUMS: “Include a link to this thread”] in your idea so product management will be able to look back at this case.
The month and week controls are working fine. I gave up on the day control per your advice.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Hello ,
Yes, I’ve talked about UltraDayView, for this component the better approach would be just to use two components and to separate owners between them.
I figured out how to get the WeekView working. It's the DayView that is the only one I can't figure out. Is that what you meant in your commment? I don't really see how to make that one work with the timeslots running down the screen.
