I have a grid with 4 columns. The first column isn't inside a group. I've set RowLayoutColumnInfo.SpanY = 4 so that it is a double-height column.
I then add a group to the grid, and set the remaining three columns to that group (RowLayoutColumnInfo.ParentGroup = MyGroup).
However, the group containing the three columns always displays before my groupless column. I can't seem to find the right property to set to change this. Any ideas?
Thanks,Campbell
Mike - As always, you are THE MAN. Thanks very much, works perfectly!
Hi Campbell,
This is controlled by the OriginX property of the RowLayoutColumnInfo/RowLayoutGroupInfo on the column and group.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { UltraGridLayout layout = e.Layout; UltraGridBand band = layout.Bands[0]; band.RowLayoutStyle = RowLayoutStyle.GroupLayout; UltraGridColumn column0 = band.Columns[0]; UltraGridColumn column1 = band.Columns[1]; UltraGridColumn column2 = band.Columns[2]; UltraGridColumn column3 = band.Columns[3]; UltraGridGroup group = band.Groups.Add("Group"); column1.RowLayoutColumnInfo.ParentGroup = group; column2.RowLayoutColumnInfo.ParentGroup = group; column3.RowLayoutColumnInfo.ParentGroup = group; // Column 0 should be the first column. So set it's OriginX to 0. column0.RowLayoutColumnInfo.OriginX = 0; // The group should be to the immediate right of the column, so determine the X position of the // right edge of the column by adding it's resolved OriginX to it's resolved SpanX. group.RowLayoutGroupInfo.OriginX = column0.RowLayoutColumnInfo.OriginXResolved + column0.RowLayoutColumnInfo.SpanXResolved; }
