1235
Valuelistitem ReadOnly
i set the UI-role / Base.Background to 'black'. In the grid every column takes the row-color, except the comboeditor (collapsed, state normal). If i select the row, the comboeditor gets the color of the row.
If i set UI-role / Base / ValueListItem.Background manually, i'm missing ReadOnly state. I got a ComboEditor inside an UltraGrid. Some activated, some not. (I prefer column Activation.NoEdit / AllowEdit, but i could do Activation.Disabled too.)
I tried, set 'All components' resolution order to ControlThenApplication and changed the color of the editor and its valuelist manually in code. No effect.
Greetz
iA. Kits
