If I use my mouse to change too quickly from one row to another that's immediately above or below, the DoubleClickRow() event seems to fire. In other words, if I click on a row and then quickly (but not even sa quick as when I double click something) click on the row immediately above it, the DoubleClickRow() event fires. Can I prevent this from happening? I can see many users of ours complaining about this as my DoubleClickRow() event handler opens another form. Thanks.
I can't seem to reproduce this behavior; are you using the latest hotfix? If you are using the latest version then you should submit this to Developer Support so that it can be reviewed.
-Matt
