Do we have any control under desktop winforms which looks and works like toggle switch similar to the one available on the following link -
http://www.bootstrap-switch.org/examples.html
Thanks in advance.
From release to release, we to try to maintain backwards compatibility with previous releases to the best of our ability. Occassionally, we encounter a situation where we must introduce a breaking change. Take a look at this help topic that has links to all the past breaking changes, and see if your application is affected by any of them.
Let us know if you have any questions.
Chris
The idea looks good but I am currently on version 11.1
Could you suggest if there are any known incompatibilities among APIs in case I try to upgrade my application from 11.1 to 15.1?
Thanks.
I am just checking about the progress of this issue. Let me know If you need our further assistance on this matter ?
Screenshot of sample:
Hello Vijay.
Thank you for adding your request to our product ideas page. If you are using 15.1 or later and only looking for 2-way toggles, you may be able to utilize our animated gif support to provide an animated switch. To demonstrate the ability, I located an appropriate animated gif online, and added it to the attached sample.
I hope this helps meet your needs.
