Now, I have one hierarchy tree with multiple levels, for example 3 levels,
these three levels use a same column "Name", when I click the "Name" column, all the level of nodes will be sorted,
do we have a way to sort just one level of nodes? for example, when click the "Name" column just sort level 1 nodes,
the order of level 0 nodes and level 2 nodes will remain unchanged.
Any comments? Thanks a lot.
Hi, Milko
This problem is solved, thanks a lot for your help.
Jing
Hello Jing,
Please check the following forum thread where same question as your was discussed and solution were suggested http://ko.infragistics.com/community/forums/t/23000.aspx.
Thank you for using Infragistics Controls.
