I'm wondering if there is a possibility to disable the minimizing of the Ribbon in WinToolbarsManager 8.1. Because I need to disallow users to do it by double-clicking on the Ribbon-Tabstrip.
I've read somewhere here on the forum that there should be a Property AllowMinimizing, but I can't find it...
Thank you, I tried it and it's good enough for me, although a AllowMinimize-Property would be more easy to handle.
There is currently no property to prevent the default double-click action on the ribbon tabs. You can handle the PropertyChanged event of the UltraToolbarsManager. If the leaf PropChangeInfo on the event args (obtained by calling FindTrigger(null) on the passed in PropChangeInfo) has a PropId of PropertyIds.IsMinimized, and the IsMinimized property of the Ribbon is False, you can set it back to True. However, you will probably see a flicker on screen. You can also submit a feature request for this ability: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
