390
Help using ButtonsLeft of UltraNumericEditor in Grid
I have a UltraWinGrid where with a numeric column that is toggable on/off.  I have created an UltraNumericEditor and added the ultraNumericEditor to the form.  I assigned the EditorControl property of the column to the UltraNumericEditor.  The UltraNumericEditor has been configured with a StateEditorButton in the ButtonsLeft collection (to toggle on/off) and a SpinEditorButton in the ButtonsRight collection (to increment/decrement by a custom amount).
I would like the cells in this column to display the numeric value and the checkbox in the grid.
 My problem is that when I check the StateEditorButton of one cell, all of the cells in the column receive the new CheckState.  I have tried using the InitializeCheckState event of the UltraNumericEditor, but I have not been able to make it work correctly.  It seems as though the Editor/EditorControl remembers the state of the last active cell (???).
 I have also tried creating a different UltraNumericEditor for the specific cell in each row of the grid.  When I do this, I get an exception if the up/down spin button is held down that the cell is not in edit mode.
 Any thoughts/help would be greatly appreciated.  Has anyone been able to get a check box and numeric editor working for cells of a column in the grid?
 Thanks in advance!
