444
How to specify the grid to display both date and time instead of just date?
I add columns and rows in the grid RUNTIME. Even if my column is of type DateTime and the value has both date and time, the grid displays only date, not time. I understand that there is a property to set that. I tried doing something like
grid1.DisplayLayout.Bands(0).Columns("Col1").Format = "mm/dd/yy hh:mm:ss"
But the steps I follow to add data to grid are are like
- Add data(rows and Columns) to a data table (m_pDataTable) at runtime from the database
- grid1.DataSource = m_pDataTable
- Set the format for required column
It works fine. But looks like its messing up the date that is to be displayed. From database to a dataRow the value when added is
" #11/27/2007 11:05:34 AM# "
And then I the steps I did was
m_pDataTable.Rows.Add(m_pDataRow)
grid1.DisplayLayout.Override.AllowUpdate = DefaultableBoolean.False
End Sub
And now I see the value displayed at output as '  05/27/07 11:05:34 '.
In simple terms, before the piece of code I wrote the m_pDatRow("Col1") = #11/27/2007 11:05:34 AM#
and after the code the value is  05/27/07 11:05:34
I couldn't understand why this is happening
Thanks in advance,        Sindhu
