220
Converting windows form e.x value into ultrachart x axis value
I am using the Ultrachart in windows application and the version is 8.2. I have created the ultra chart as Composite chart with numeric time axis. for x axis datatype is time  and y axis datatype is  numeric . then  i have add the two types of chart, step area chart and stack area chart and i have binded these charts using series. I want to capture the datavalue of the chart in mouse double click event So that i am capturing the  mouse  click event and  i am able to capture only the form x value not ultra chart x xais value.  How i can convert the value into the Ultrachart x axis value.
 Note:-
 the chartdata click event  is not firing because i ploting chart using the series but not in datasource
Private Sub UltraChart1_MouseDoubleClick(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles UltraChart1.MouseDoubleClick
' Here i am able to capture only the e.x as form x axis i need to convert to ultrachart value
End Sub
Please any one help how to convert the windows form x value to a ultrachart x axis value
  • 17605
    With current chart API you are unable to convert e.x value to ultrachart value in МouseDoubleClick event. ChartDataClick event is raised when you click on the specific data value (in your case this are just the points).
    You can try looking at our "Interactive chart" WinForms Chart samples in version 8.2. It is possible to find the functionality you need there.
