I know how to get the rectangle, it is the Rect property. Do I have to walk the parentage to generate the screen relative rectangle, or is there a simpler way?
For instance, I want the screen relative rectangle of a RowUIElement within an UltraGrid.
Yes, thank you.
Can you use the RectangleToScreen method off of the grid (which is a property off of Control)?
-Matt
