444
How to set current date format in the system to the column format?
Hi I have used the following statement to set the date format of a column in the grid.    grid1.DisplayLayout.Bands(0).Columns("Col1").Format = "MM/dd/yyyy hh:mm:ss"  But I am hardcoding the format here. And if this applicationis run somewhere in UK they would expect dd/MM/yyyy format. So, is there a way I can specify the Format of column to make use of current date format of system. I tried assigning it System's DateTime Format. But they are different in cases which is increasing my code a lot. So what could be my next option to specify Date,Time (12hrs format) of current system?
Sindhu
