2085
Change axis range without changing tick mark values
I have a time-based line series with markers turned on that has one data value per half hour in a 24 hour period starting from midnight.  I have the CategoryDateTimeXAxis Interval property set to 1 hour.  When I graph this, I have a nice set of hour tick labels (00:00, 01:00, 02:00, etc) but I see the markers for the first and last points in the series are cut off by the edge of the chart.  I have attempted to adjust this but adding 15 minutes to the CategoryDateTimeXAxis min/max datetime values, which brings the full marker into view on the chart, but changes tick labels to 15 minute bounds (23:45, 00:45, 1:45, etc).  How can I adjust the min/max just slightly to make the end point markers completely visible and NOT change the tick mark labels?  There is a similar issue on the y-axis.
Attached is an example program, click the "Switch" button to adjust the chart x-axis min/max back and forth and note the x-axis label change.
Due to the way I have a CategoryXAxis and series on that axis over-laying the above CategoryDateTimeXAxis, I cannot simply shift the min/max by the interval time(1 hour), so I need a different option than that.
ShiftingDataChartAxisLabels.zip
